Constraints not updating
ericschimel
ericschimel
So I have this model that I'm working on and for reasons that are beyond me I cannot get the "Plywood" constraint to work consistently.
I model a fair bit of things like this and I've noticed that if I have a complex sketch that Fusion gets incredibly slow recalculating the constraints. I ran into that again on this model and the only solution I've found is to break up my sketches into tiny parts so I don't get so many failures.
Ideally I'd like to have one master sketch to drive all of my components, this would make things a lot easier because I could do a lot of referencing from part to part. Because I have to break my sketches up into smaller bits I'm forced to make a lot more attributes to reference across sketches.
In this particular case I cannot get the "Plywood" attribute to recalculate. If you check the screen cast you'll see that I get an error in "Sketch 5" when I try and use a different plywood number:
http://autode.sk/2hmOAI6
Oddly though when I go into the sketch and simply double click the dimension and hit "enter" it all works again...
Am I seeing a bit here, or do I have a poor approach to doing what I need to do here?
jeff_strater
thanks @ericschimel for reporting this.  The combo of the video and the model made it very easy to reproduce the problem.  We really appreciate that level of effort.
I will file a bug for this and have the team look at it.  I've also found that when you hit this problem, an Edit ->  Compute All seems to fix the problem, and is easier than editing the sketch.
Jeff
Jeff Strater
Engineering Director
TheCADWhisperer
@ericschimel wrote:
Ideally I'd like to have one master sketch to drive all of my components, this would make things a lot easier ...
Here are my preferences.
I too like to use a master sketch - but I only define the basic extants.
I try to never duplicate work in sketches (I see an awful lot of duplication in your sketches.
Pattern features, not sketch entities and certainly not sketch dimensions.
I prefer to make use of symmetry about the origin in my sketch and use = constraint rather than duplicating dimensions.
I fully define all of my sketches.
I think the number of dimensions you are using can be significantly reduced.
ericschimel
Thanks @jeff_strater!
@TheCADWhisperer You're right that the sketch could be reduced in complexity, I actually imported that one as a DXF and it came in completely un constrained so I had to constrain and dimension every line to make it work. I did as much symmetry as I could... I've found that using mirroring in sketches isn't that reliable, so usually I just sketch half or a 1/4 of what I am making a solid, I extrude it and then combine it back together.
What would you recommend I do to make this sketch a bit better? Make a master sketch and then project for each individual part?
ericschimel
Hey @jeff_strater where are you seeing that "Compute all" button?
TrippyLighting
This is like your design quality control.
ericschimel
Thanks @TrippyLighting. So I'm hitting "computer all" both in, and out of the sketch and it's not re-computing unless I double click on the dimension and hit enter again...
