09:09 AM
- In SIMULATION: See attached or imagine a simple CONE washer with flats at the top and bottom. Apply pressure (or displacement) on the top surface diameter and ONLY fix the Z axis displacement for the bottom surface. Every combination gives an error such as:
"There are probably not enough structural constraints"
and the simulation results are empty.
Imagine a cone washer with flat top and flat outer bottom bearing surfaces (Dorman makes a flanged lug nut that has a washer like this attached to their nut). I can apply pressure (or Z displacement) to the top bearing surface, and I need to only fix the Z axis on the bottom bearing surface. - Also, if I try to displace only the Z axis on the top surface and fix only the Z axis on the bottom surface (and then look at the stresses), I get the error,
No structural load applied.
Fusion 360 is far far easier and more powerful than the free z88 product (FEA only), but z88 lets me fix only the Z axis on the bottom bearing surface and apply pressure on the top bearing surface. - Also, it would be very convenient for users to be able to SLICE the Simulation results along a PLANE. See attached. Again z88 lets users do this easily. The new Fusion 360 lets us look into the Simulation results, but not a slide simulation result (see attached examples from Fusion 360 compared to z88).
Even with this, Fusion is the best and easiest CAD/CAM package I have ever seen (but I do not have much experience in this field). Thank you for making such a package available for startups and students who just want to play with designs.
I never knew CAD, FEA, CAM could be so integrated and have such an easy user interface.
Geoff
