Constraint - Square inside Rectangles
Nickeliovich
Nickeliovich
I'm new to Fusion 360, but constraints give me a real headache.
I want to constrain centre of the 10x10 box to the intersection of the midpoints of the short sides of the two rectangles.
I will using parametic dimensions and I want the box to remain centred.
i throught this would be really stright forward using two midpoint constraints (one on the vertical side of the box, other on the horizontal side). I also tried colinear constraints, but you can't create a colinear through the midpoint of a line. I'm sure there is a really elegant solution without drawing construction lines, but after 2 hours I'm stumped.
g-andresen
just try it this way
günther
jeff_strater
here are a couple of ways to do it, in the attached video
Jeff Strater
Engineering Director
Nickeliovich
Thanks, but that's not where I wanted to place the square.
Do you think it possible to do using two contraints or do I need construction lines too?
Nickeliovich
Thanks Jeff,
Of course using dimenions makes sense if I'm trying to define Parametric Dimensions, I got hung up on trying to use constraints. I think I was on the right track, but needed to create midpoints first, before constaining.
jhackney1972
You can do the constraining of the rectangle in the position you want it using two constraints.  The key is to use the hold the Shift key while you are selecting the midpoints on two sides of the square sketch.  The Screencast will show this process.
John Hackney, Retired
Nickeliovich
Thanks John,
I knew there must be a simple solution using constraints. I was trying all the wrong ones!
