Constraint failure?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've encountered a scenario where a drawing shows as fully constrained but there are multiple possible locations for the geometry. This manifests with items changing position when user parameters change.
I've attached a screencast of a simple example.
There is a large circle anchored at the origin that is dimensioned by a user parameter. There is also a radial line of fixed length with a vertical constraint. Two smaller circles of fixed size are present and each is constrained to be tangent with the line and the large circle. Where they end up in the geometry is dependent on their initial location, but both show as fully constrained. If the parameter defining the size of the large circle is changed they may change location in different ways.
Is there a solution that I am missing somewhere?
