Constraint bug?
Constraint bug?
etfrench
Mentor Mentor
Constraint bug?
etfrench
In this sketch a rectangle was created, then a line offset down from the top edge.  A line was added 2.5" above the origin:
Adding a dimension between the endpoints of the offset line and the added line creates a normal dimension, but both lines are already constrained horizontally as well as vertically dimensioned.  Expected result is a driven dimension.
Note: If the dimension as created between the lines, not the endpoints, then a driven dimension will be created.
ETFrench
TrippyLighting
I think that isn’t a constrained bug, but yet another indication that there is something inherently flawed in how offsets are implemented.
MichaelT_123
Hi Mr. Peter Doering, aka TrippyLighting,
I tend to agree with your statement. Offset is an expensive and not always reliable function. Yes, it is helpful in many circumstances, but it should be utilized as a last resort.. which is not the case in the example presented by Mr. ETFrench.
There are some siblings of the standard offset. Some are swimming in the Pacific Indian Oceans now, but if? I catch them,... I will 'show' them on the Forum.
Regards
MichaelT
MichaelT
MichaelT_123
Hi Fellows,
As I anticipated in my post ...
I caught them! … and will present the respective stories in separate posts over the following days/week.
Their title will start with the acronym CSF, followed by more or less meaningful descriptions.
Regards
MichaelT
MichaelT
