Constraining splines in sketch mode
andrewR62MC
Message 1 of 26
andrewR62MC
Hi, I've started using splines, but don't know how to fully constrain them. Anybody have any thoughts?
Replies (25)
Message 2 of 26
lichtzeichenanlage
The quick way is to right click -> Fix / UnFix it. But this is not parametric and might come with some drawbacks. The "proper" way is to constrain the spline points and handles with dimension and / or constrains.
Message 3 of 26
Urbanthor
when moving a sketch with splines, I have to constrain both the points and the handles. so one spline needs to be constrained 6 times. ><
Isn't there A better way?
I just spent an ungodly amount of time constraining the splines just so I could coincident the sketch ...
Message 4 of 26
g-andresen
1. What is the reason that forces you to move a sketch? I do almost all position changes with components and joints.
2. Control point splines need only 2 dimensions per point.
günther
Message 5 of 26
TrippyLighting
So here's a question that might border on heresy for some folks:
Why would you need to fully constrain and dimension a spline?
Message 6 of 26
MichaelT_123
Hi Mr. Guenther Andresen,
generally ... only 3 dimensions per point ... 😉
Regards
MichaelT
MichaelT
Message 7 of 26
therealsamchaney
Each spline point has a handle (a line connected to the point that controls the curvature at that point) so for every one of these points you'll have to fully constrain this handle line.
To do this you will need to make an X and a Y dimension to constrain the point, then a width and an angle dimension to constrain the handle line.
So, that's 4 dimensions for every point in the spline. If you have some of the points constrained in some other way like with coincident or tangent, you won't need all of these dimensions for those points.
You can also choose to only constrain the X and Y of the points but leave the handles unconstrained so you can adjust the curvature still.
Message 8 of 26
patmat2350
"You can also choose to only constrain the X and Y of the points but leave the handles unconstrained so you can adjust the curvature still."
This has caused be problems! I now understand that the handles require constraints, but in the past, simply constraining X-Y coords for points would turn the spline black, fooling me into thinking the spline was constrained. Silly me for thinking that!
So, add a line segment tangent to the end of the spline (or parallel to the end handle, same thing I think?), and adjust the distal line end point, and Shazzam! The spline goes out of shape. @$%$#!
I do see that if at least one handle has been adjusted, the spline turns blue again.
Suggestion to the UI team: ANY unconstrained spline should be blue!
Adding to the confusion: Sketches containing these pseudo-constrained splines get the red padlock ( https://forums.autodesk.com/t5/fusion-360-design-validate/what-does-a-red-quot-lock-quot-icon-mean-o... ).
When working on boat hulls, I may have a score of splines having a score of points each. That would be a lot of constraints to add.
Message 9 of 26
TrippyLighting
It would indeed be, but that many fit points for a spline  is also a surefire way to create splines with horrible curvature. Having as many splines as you have in the image you posted is equally a surefire way to create surfaces with bad curvature.
Message 10 of 26
patmat2350
I agree it's an issue. But I'm recreating historic vessels here, and my own simplified splines will rarely follow the original lines well enough to satisfy me.
Side note: The data tables ("Table of Offsets") defining these shapes, at least in the UK & USA, were defined in feet/inches/eighths of inches. The old draftsmen did good work, but I often find that some points need tweaking within the rounded eighths to achieve decent fairness.
I'm afraid I don't know much about control point splines... I wonder if they would do a better job in fairing the data?
Message 11 of 26
TrippyLighting
It is a mathematical issue. The NURBS math doesn't care how old the vessels are 😉
@patmat2350 wrote:
... but I often find that some points need tweaking within the rounded eighths to achieve decent fairness...
How do you judge fairness of a spline, or surface ? Are you using the tools in the inspect menu?
For example the curvature comb on splines of edges, or the Zebra stripes or IsoCurve analysis on surfaces?
@patmat2350 wrote:
...I'm afraid I don't know much about control point splines...
The old draftsmen and boat builders bent wooden sticks around pins to create smooth curves> These "wooden sticks" were the first splines. Then much later mathematical formulae were developed that resembled the behavior of such sticks.  Those Bezier curves also were called Bezier splines. Fitpoint splines in Fusion 360 are 5-degree multi-span B-Splines.  The more fitpoints you add to such a spline, the more complex that mathematical monster becomes.
While ultimate curvature quality is unlikely needed for projects such as these, I would really limit the number of fit points and number of splines and try to get the overall shape of the boat correct.
No, because you can only manually control/move the CVs (control vertices.) They are simply easier to handle when creating gentle curves.
Other CAD software sometimes includes algorithms to fair splines for a best fit through data points. This does not exist in Fusion 360. If you want to go down that rabbit hole I would look at software specialized for boat builders. But I doubt that's really what is needed.
Message 12 of 26
patmat2350
Math don't care... but I do!
And it's combs on splines. I confess, it's hard to appreciate the meaning of the comb magnitude... or to get the comb as smooth looking as I would like... but on, for example, this convex curve, I'm happy to get all the comb on one side with no curvature reversals.
Message 13 of 26
TrippyLighting
When you're using computer software math and algorithms have the last word, no matter how much you care.
Suit yourself.
Message 14 of 26
patmat2350
"...but that many fit points for a spline  is also a surefire way to create splines with horrible curvature. Having as many splines as you have in the image you posted is equally a surefire way to create surfaces with bad curvature."
Oh, I'm happy with my abundance of spline points...
Message 15 of 26
lichtzeichenanlage
That's a nice model. But unfortunately a rendering doesn't gives away to much information. Can you show an e.g. zebra analysis of the hull? As you can see, both bodies do look fine in the design view but not in the zebra analysis. And I only added 3 additional rail profiles.09-08-2022 09-50-48.png
And the bodies are nearly identical
Message 16 of 26
wersy
Are all combs really that smooth?
Very rarely do you get such exact profiles for a boat.
You can't tell from the picture how perfect the hull is. Anyway, it looks very good, a nice job.
What kind of boat is this? It looks like some kind of lifeboat.
Can you post a link to it?
Message 17 of 26
lichtzeichenanlage
CurvatureMap is great to show surface problems too:09-08-2022 14-11-14.png
Message 18 of 26
patmat2350
"Are all combs really that smooth?
Very rarely do you get such exact profiles for a boat."
First, I really only need to make the render look presentable, I won't be machining a perfect shape from billet or any such.
If a physical model is made, it will be "old school"- cutting frames from wood on a bandsaw, sanding fair (enough), planking, and sanding again.
And no the original data wasn't perfect. The occasional mistake in tabulated data from a 1909 draftsman, and everything rounded to 1/8 inches. So I used curvature combs to refair the individual frames a bit, and added as many rails along the waterlines as possible.
And yes it's a lifeboat for the US Life Saving Service.
https://www.rcgroups.com/forums/showthread.php?4169297-US-Life-Saving-Service-36-Elco-boat
Message 19 of 26
lichtzeichenanlage
You just want a rough model? Fine. But...
  • Why run through all the effort and creating so many sketches the goal is a rough model.
  • Don't say that many curves are a good solution without saying that you don't care about the surface quality. Because this way your post doesn't help other users
  • I'm not sure if the back of your hull is even convincing in the rendering. But perhaps this is just a strange reflection.
Any chance that you can show us a zebra analyzes or curvature map? Doesn't take much time to do this.
Message 20 of 26
patmat2350
It's not a rough model- it's very true to the original.
I don't give a hoot about the analytical capabilities of some striped horse- the shape is correct, and smooth enough to appear fair in images. Maybe it could be smoother, who cares? If it's smooth but wrong because it has only three sections and two rails, it's of no use to me.
And I assure you, my boat's butt is near perfect- you're likely confused by the turn of the bilge versus the deadwood area.
