Constraining Multiple Circles to One X-Axis/Y-Axis Dimension
I'm pretty new to fusion 360, and I need some novice help.
Currently in my design, I want multiple circles to have the same x-axis/y-axis constraints, but I can't figure it out. Attached is a picture. All the dimensions circled in red I want to have one dimension in the x-axis or the y-axis to control all of them instead of having multiple dimension stating the same thing. How do you do that?
Having multiple circles with the same x or y dimensions will help with editing the entire project faster and will make the project look more professional. Thanks.
dsouzasujay
Hi @Anonymous ,
After creating the sketch you can use "Horizontal\Vertical" constraints to align.
I have attached a screencast video to explain.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
TheCADWhisperer
See Attached file.
Those of us who grew up mid-way through the last century on the drawing board learned that construction lines are your friends.
Also make use of Geometry Constraints like Horizontal, Vertical and Equal as indicated by @dsouzasujay
