Constraining bodies to sketch points to obtain variable extrude
dgmshop
dgmshop
I’m not sure of the method or approach to achieve the following scenario. I would like to sketch four circles at equal intervals, side by side, spaced evenly along a common centerline. I intend to have a construction line connecting the “first” circle to the “fourth” circle and “connect” the remaining circle center points to the construction line. I would like to be able to extrude these shapes to varying heights by manipulating the angle of the construction line in a plane perpendicular to the faces of the circles. For example, if the construction line were changed to 3 degrees over 14” for example , the 4th circle extrude would be around .700”, maybe the 3rd circle .500” etc, assuming spacing of 4.3”. These are not precise numbers, just estimates. I would like to be able to manipulate the angle of the construction line in the sketch to achieve variable extrusions of the 4 bodies. (The datum or first circle at 0,0,0 will not move or change, only the 3 “upstream” along the path of the line)
I’m not certain if this would be achieved with constraints based on the construction line being locked to the center point of the 4 sketched circles, or another function in the 3D environment. I also suspect there may be a method involving prametrics. I’m still learning about constraint elements, I’m hoping someone may decipher this description and provide some guidance. I apologize if I’m not clearly describing the function I’m trying to achieve.
Thank you for taking the time to read this post.
davebYYPCU
I think I have it.  Set up dimensions / parameters to suit.
Initially you need a Pipe / Extrude for each centre line in this method.
change the top line angle the bodies will update.
if not pipes then need a sketch of profiles, at each centre line.
Might help....
g-andresen
one more
or is it something like this?
This is even easier to realize
günther
davebYYPCU
Why construction Planes, when the end point of the centre line is at the same place?
3 items / timeline icons of duplication.
g-andresen
Good question!
Force of habit?
günther
dgmshop
Thank you very much for the quick reply, this fully solved my issue. Much appreciated!
dgmshop
Thank you kindly for taking the time to demonstrate your method, this was very helpful. I feel there is merit to both suggested methods, and I really am glad to have had support for this query. I had success with both suggestions,
Thanks for your help!
