Constrain To Axis
Constrain To Axis
Lonnie.Cady
Advisor Advisor
Constrain To Axis
Lonnie.Cady
Is it possible to constrain a sketch segment collinear to an axis?
I have tried and can't figure it out.
rishivadher
Hi
The way I found to make a sketch collinear to the axis is on the sketch "project" the Axis in this case YY and XX, to center the sketch so can use the features like symmetries, this a small example the image below
Best Rishi
Lonnie.Cady
Thank you that works well.  Coming from SW I was used to being able to dimension to the the origin planes and axis and not really sure what to do here.
rishivadher
You can submit your ideas at
http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/idb-p/125
Keep in mind that Fusion 360 has just over one year, and SW has decades of development 😉
best
Lonnie.Cady
Thanks, I did not want to imply that SW was better, just how I was used to doing things.  I know each software has its own method and wanted to learn the Fusion way and only used SW as a reference that I was used to.
rishivadher
yes the same here, i used to work with SW, and learning Fusion
