- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to constrain a sketch segment collinear to an axis?
I have tried and can't figure it out.
Hi
The way I found to make a sketch collinear to the axis is on the sketch "project" the Axis in this case YY and XX, to center the sketch so can use the features like symmetries, this a small example the image below
Best Rishi
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
Thank you that works well. Coming from SW I was used to being able to dimension to the the origin planes and axis and not really sure what to do here.
You can submit your ideas at
http://forums.autodesk.com/t5/Fusion-360-IdeaStation-Request-a/idb-p/125
Keep in mind that Fusion 360 has just over one year, and SW has decades of development 😉
best
Rishi Vadher
Personal Page
Thanks, I did not want to imply that SW was better, just how I was used to doing things. I know each software has its own method and wanted to learn the Fusion way and only used SW as a reference that I was used to.
yes the same here, i used to work with SW, and learning Fusion
Rishi Vadher
Personal Page
