Constrain an arc in two equal parts through a line
Hi all,
first, the project: https://a360.co/3fwKjwc
Do you see the 30° arc on the right? I want that this arc is positioning in the half down the X axes (so 15°) and half up (the other 15°).
I've tried with "constraint midpoint" but this doesn't work.
How can I do?
davebYYPCU
No.
Use Coincident, on the arc midpoint, to the line.
Might help....
But the problem is that midpoint of the arc isn't defined, so I can't snap an "non-existent" point to something...
davebYYPCU
That's not true.
Click Coincident, Hold shift key down, and hover mouse over the middle area of the curve,
when the glyph appears click on it, then select the line to attach to.
Might help....
It works!
I had to study all of these key combinations, thank you!
