Connecting lines from sketch
I created some curvy lines in the sketch and extruded them.
I want to connect them on the top on the extrusions.
Is there any way to do that?
Replies (8)
g-andresen
please show in a screencast what you want to achieve
günther
I want to connect the walls like in the picture with the red line (not just with a line, with a full face).
g-andresen
1. create a sketch plane
2. project the contours of the surfaces & add needed lines
3. create surfaces from projected lines
günther
davebYYPCU
Need the file to be sure of this,
go back to the sketch you had for the other walls, and add the red line,
Edit the extrusion feature, and select the new line.
Will only work like that if you have a history timeline.
Might help....
Thank you @g-andresen
kackako
Community Visitor
Community Visitor
Is it possible to connect all the lines so that I can draw the sketch?
davebYYPCU
Looks like new sketch for each line, to connect,
all lines should be in the same sketch.
Might help….
TheCADWhisperer
@kackako
