Connecting 2 faces at different angles in sheet metal
petrenc
Message 1 of 19
petrenc
I am designing some trailing arm brackets with the help of a 3d scan mesh. The goal is to cut the brackets with cnc plasma and bend to shape. The brackets have two sheet metal faces at different angles that need to be joined. I have tried lofted flange in sheet metal, and Loft in solids with no success. The Loft function in solids worked to connect the two pieces of sheet metal but it wont allow me to create a flat pattern. The picture shows the angle differences and where they need to meet. Any help is greatly appreciated. Thank you
Replies (18)
Message 2 of 19
jhackney1972
Please attach your model.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it. If needed, ZIP a F3Z file.
John Hackney, Retired
Message 3 of 19
petrenc
Model has been added to my original post
Message 4 of 19
TheCADWhisperer
@petrenc
See Attached.
Message 5 of 19
petrenc
I was able to create that as well with lofted flange but not exactly what i'm looking for. Too many bends and aesthetically unpleasing.
Message 6 of 19
petrenc
This is what im looking for which was created with loft in the solids toolbar. Only problem with this method is the intersecting piece becomes thinner than the other plates which goes against sheet metal rules and wont allow me to create flat pattern.
Message 7 of 19
TheCADWhisperer
@petrenc
That is not the file that you Attached here for reference.
You have a twist in the material.
You will have to use Meshmixer or Autodesk Inventor Professional - Unwrap function
or
align those edges such that the transition is planar rather than twisted.
I will give it a try when I get a chance.
Message 8 of 19
petrenc
Correct, I tried attaching that image in the first post but the forum only allows 3 uploads. I felt the other 3 were more helpful.
And yes the two faces are not planar but if it is possible to complete the desired shape with loft or even a piece of paper then its definitely possible in fusion.
Based on my CAD(cardboard aided design), each top and lower flanges must have a different angle to accomplish it being cut out of a flat plate of steel. How to figure out those angles is beyond me. Maybe using bends instead of flanges?
I appreciate you giving this a shot!
Message 9 of 19
petrenc
NVM I take back what i said about my ''CAD''. The top and bottom pieces dont have to be different angles on the connecting sides. Just the connecting piece has to have different lengths on each side. I dont know if im even making sense at this point. Might just be talking to myself at this point. lol
Message 10 of 19
TheCADWhisperer
@petrenc
See Attached.
Message 11 of 19
petrenc
Fantastic!! Share your secrets!!
Message 12 of 19
TheCADWhisperer
@petrenc
No secrets - all steps are recorded in the Timeline.
We could also straighten these edges of Flat Pattern for manufacturing purposes but might not look as good in bent form.
Message 13 of 19
petrenc
Thank you! Ive never used the surface tools and now I see how valuable they can be. I dont think theres a need to straighten the edges for manufacturing purposes as I will be cnc cutting it from sheet.
Thanks again! Problem solved!
Message 14 of 19
TheCADWhisperer
@petrenc
I hope you haven't made the part yet.
That was just my first attempt to understand the geometry.
In a few minutes I will post video of improvement on the geometry angles.
Q. What scanner did you use to can the part?
https://youtu.be/ms4MU7Y-qIo
Message 15 of 19
petrenc
Im in the middle to sketching it still. I have the geometry figured out I think but having a hard time putting a fillet on the edges before converting to sheet metal.
Ill watch the video first and keep you updated.
The scan is from KIRI Engine app on my phone.
Message 16 of 19
TheCADWhisperer
Must Stitch the surfaces together before Fillet.
Message 17 of 19
navya_gelli
Hi @petrenc ,
Did the info from @TheCADWhisperer help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Best,
Navya | Community Manager
Message 18 of 19
petrenc
Yes there has been a solution to my problem. Thank you CADwhisperer!
Message 19 of 19
petrenc
This worked perfectly for me! Thank you so much!
