How do I create and Flatten a conical bend in Fusion sheet metal?
@arie.dv wrote:
@arie.dv wrote:I can see that you have lines creating triangular portions, which I assume are the planar faces and the conical bends are the areas in between. What I don't understand is how you create them.
Regards, Arie.
PS. Here is the final product that I wish to produce.
I finally figured it out. I need to create a sketch with rails between the circle and the rectangle. Which is then used by the loft to create the planar faces.
Regards, Arie.
Well here is my final rendition of the round to rectangular adaptor. It may not be elegant but it achieves what I want.
When I go into flat pattern mode the flat pattern icon in the timeline is highlighted, but right clicking doesn't show any warnings and there are no warnings in the model timeline.
Any ideas why?
Arie.
