conic constructions, exact equations, finding tangents
How to enter a exact dimensioned curve, and/or find the tangent at a specified angle to a general sketch curve
I am trying to make Oblate Spheroid geometry based loudspeaker horn/waveguide
the geometry is a surface of revolution of a 2D hyperbola
characterized by hyperbola asymptotic angle and the size constraint of matching a selection of specific compression driver exit angle and diameter numbers at the throat
I can guess at a couple of approaches that have a heavy math preprocessing burden, would require typing lots of high precision digits
the 3 point and Rho conic entry method needs considerable math to hit the curve starting from the parameters I have – and I can't find where you document the equations you use that would let me make the calculation
I believe a 2D spline could also be calculated to give an exact fit to a hyperbola – again clear documentation – cold hard equations documenting what your splines are made of, how to enter the parameters – would need to control slope and curvature awkwardly at the throat endpoint with tedious calculation in other math tools
obviously I'd much prefer a native geometry driven approach
I can literally make a cone by revolving a triangle with the asymptotic angle
slice the body in a plane offset from the cone axis, project the face to a sketch plane
and then I'm stuck – can't apply a tangent constraint to snap a line with the correct angle slope from the axis to the curve
I can't seem get a line to snap tangent to a 3point, Rho conic sketch either – constraint syntax, grammar needs clearer explanation – words please, actual written documentation?
Use of tangent handles to modify curves makes disambiguation difficult
So far I can only make the specified angled line snap tangent to a circle or ellipse (although 1st try warped the ellipse, “fix/unfix” made it do what I wanted)
even then the intersection point doesn't appear, I have to trim away the construction line to get the endpoint of the curve
maybe a pic helps
I have done the complete construction in PTC Creo stating cold with no 3D CAD experience in ½ the time I've spent so far not getting to step 2 with Fusion
I really want to get to the CAM part of Fusion, cutting the layers from .stl was painful when Cut3D insists on raster finishing pass
innovatenate
Autodesk Support
Autodesk Support
There is a script you can run to import points from an excel spreadsheet (CSV) file to generate a curve. You may need to set up the equations for a curve in the excel sheet first. Take a look at the below autodesk screecast for more details.
https://screencast.autodesk.com/Main/Details/35f7beac-de8a-47c8-9ef7-0f927ab15b3d
You raise a good point on the conic curve tool. The documentation is a little bit light.
My best guess at the moment, since the values range from 0-1 for rho, is that:
  • Values of rho less than 0.5 result in an ellipse.
  • Values of rho greater than 0.5 result in a hyperbola.
  • Values equal to 0.5 result in a parabola.
However, I will seek verification of this and report back to you to confirm this for sure.
As far as the point, you can create a point in the sketch and then add a coincident constraint between the line, curve and the point to locate the tangency point as well.
I hope this helps, I will return with confirmation. Please let us know if you have any other questions.
Thanks!
Nathan Chandler
Principal Specialist
ShirleyShi
If you imagine the conic as a rounded corner, then Rho is the ratio of the distance of the peak of the rounded corner to the sharp corner (D1/D2) (see below picture).
About the tangent constraint issue, could you record a video to show the problem more clearly? We support auto-add tangent constraint when creation if you select the intersection point of the connecting curves while inferring as vertex point.
Shirley
Developer for Fusion Electronics
Autodesk, Inc.
I want a fixed geometry hyperbola - with specific dimensions/geometry - you haven't begun to tell me what the controlling equations are
once I have the correct hyperbola I want to find the point at wihich a tangent to the curve has a given angle relative to the axis
I can snap a given line drawn with a angle input to be tangent at that angle to a circle or ellipse - but not to a general spline curve - is this not yet implemented for hyperbola or spline curves?
also with the spline - no refence of the actual equations from which I could derive the inputs to hit an exact curve - since you apparently  use a 5th order fit I can't gues the form of the end constraints where curvature, rate of curvature inaddition to tangent angle would seem to be needed
