Confused with deleting bodies after a revolve
4 REPLIES 4
jscott6SWZG
203 Views, 4 Replies
I would have thought this to be simple?
Anyway I revolved and cut a 180 deg torus profile into a body....worked fine.
But of course it left two floating bodies where the profile did not intersect the original body...
So I selected one body from the browser and tried to delete it... worked but deleted the whole revolved cut???
Now I am stuck.....
Appreciate  any help
4 REPLIES 4
davebYYPCU
in reply to: jscott6SWZG
Yep, expected behaviour - do not Delete.
Use Remove, instead.
Might help...
jeff_strater
if you are interested in the background on this, take a look at this thread:  what-is-the-difference-between-delete-and-remove
Jeff Strater
Engineering Director
Bunga777
In that case, you can select the body you don't want and choose Remove from the right-click menu.
However, if you don't want the part in the first place, it is better to change the sketch like this.
If you choose the added areas together when you Revolve, you will not have an extra body.
jscott6SWZG
Thanks much   I missed the obvious again
Technology Administrators
