- Mute
- Permalink
- Report
I am learning Fusion 360 by diving in to some demos and tutorials. I'm working on fully defining/ constraining 2-D sketchs. I am in this example:
"Learning > Sketch > Hands-On exercises > Fully-defining a Sketch > Steps 10 - 13"
I am working on the example, and have set up the plate, the cut-outs and so-on. I have mirrored the cut-out across the construction line bisecting the plate. I am trying to apply a Concentric Constraint to the centre of the two arcs on either side of the cut-out, step 10 in the procedure. The Concentric constraint is greyed out., and I cannot invoke it at all. I've tried invoking it first5, then the centre-points, I've selected the centre-points and then tried to select the constraint, I've selected the arcs rather than the centre points, etc. but cannot get this constraint to stick. Any suggestions as to how to proceed?
Thanks!
