Concave a flat surface
BLD-Designs
Message 1 of 15
BLD-Designs
Searched around  Google for a bit, found no good solutions.
How do I make a flat area in the pic concave?
Replies (14)
Message 2 of 15
jodom4
Hey RC-CnC,
Use the Fillet tool (in the Modify menu) on both of the side edges at the same time. This will give you fillets and a concave surface.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 15
TrippyLighting
While @jodom4's answer might be why you re looking for, "concave" can mean a lot of things and there are a number of techniques to address that.
Message 4 of 15
SaeedHamza
Here is one way to do it
Saeed Hamza
Message 5 of 15
TheCADWhisperer
Are you looking for a Revolve-Cut to provide clearance for a roller/wheel to be mounted between those posts?
Do you have a picture or link to a similar object?
Can you File>Export and then Attach your *.f3d file here?
What is the meaning of life?
Message 6 of 15
BLD-Designs
Yes that is what I'm looking to do
Message 7 of 15
TheCADWhisperer
I noticed that Sketch1 is not fully defined or making use of obvious symmetry about the Origin.
If I provide step-by-step modeling instructions, would you be willing to start over from the beginning?
Message 8 of 15
BLD-Designs
Sure.  The model only took me 5 minutes
Message 9 of 15
TheCADWhisperer
Start a new part file.
Sketch the 3 rectangles as shown.
Note the position of the Origin.
Attach the file here for the next logical step.
Here is an image of the three rectangles without the dimensions - note the included vertical Construction Line.
Message 10 of 15
BLD-Designs
OK next
Message 11 of 15
TheCADWhisperer
I am trying to demonstrate to you a rock-solid robust modeling technique sometimes referred to as the BORN Technique.  (Base Orphan Reference Node)
A foundation to the BORN Technique is logical instructions.
You completely missed one of my instructions.
Message 12 of 15
BLD-Designs
Sorry being a 50 yr old, I didn't think I need someone to check my work
Message 13 of 15
lichtzeichenanlage
@BLD-Designs: I am 48 years old and hope that in two years' time I will still be smart enough to know that you can still learn new tricks.
Message 14 of 15
TheCADWhisperer
Well, I'll be 61 in a month.  In the previous 60 yrs (30yrs using CAD) I have learned to verify everything.
First thing I noticed is that your sketch is blue while the image of my sketch is black.
This indicates that your sketch is not fully defined.
Here is one example.  I probably would have done as one side and Mirrored, then added the Counterbored cylinder and hex... ...but for what it is worth - turn on your sound.
Message 15 of 15
BLD-Designs
Thankyou very much for your time.  I have not been using Fusion 360 that long
Yes that is what I am trying to accomplish. Basically a relief for a pulley
I'll work on an sketching using an origin plane like your example.  It's an interesting way of creating a model.
Please let me know if the attachment is correct
