Compute All fail on imported dxf
Compute All fails on this imported dxf, ellipse_polyline3.dxf, with the message:
"Fail to generate profile, usually because some curves overlap but not exactly."
The dxf originated in the file, Ellipse_dxf_Parent.f3d, from Component2/Sketch4. The short elliptical arcs were created by using the break tool. There are no error warnings on the sketch in this file.
The changes made in the 2d Cad program, Visual CADD 6.0, were to remove the arcs and draw the straight lines. Both of these operations could have been done in Fusion 360, but the tools in Visual CADD were easier to use. Visual CADD also exposes the properties of the geometry such as the following:
#1 [Ellip Arc], UID: 245, Layer: 0, Color: 15:(LP), LnType: 0:(LP), Width: 0:(LP), #Pts: 7
p1: -105.00000mm,0.00000mm p2: 105.00000mm,0.00000mm p3: 0.00000mm,88.83173mm
p4: 0.00000mm,-88.83173mm p5: -15.44683mm,87.86522mm p6: -16.03777mm,87.78941mm
p7: -16.62818mm,87.71075mm
Length: 1.19141mm, Area: Not Closed sq
ETFrench
