I have created an assembly of assemblies. The fold frames positions can not be adjusted by editing the joint command or by using the move command once the joint is placed. Why can't I refine the position of these components. Their relative positions define the entire mechanism.
Solved by DonCMorrison. Go to Solution.
Solved by jhackney1972. Go to Solution.
The only Joints I see in the Assembly, that are something besides Rigid, move just fine. Please clarify if these are not the joints in question.
John Hackney, Retired
The fixed joints which position the fold frames to the pontoons are the issue. I insert the fold frames into the assembly which initially just contains the two pontoon assemblies. The right pontoon is grounded. I then joint the front fold frame to the front of the right pontoon. The joint creates the mate in the lateral direction and I can adjust the vertical position to get the top surfaces aligned. It is the position fore & aft that is the problem. I can adjust in using the joint command but when I hit enter the relationship moves to some other position (extended forward of the desired position. I have the same issue when I position the rear fold frame. The joints between the fold frames and the left pontoon should position it relative to the grounded right pontoon, but again, I have issues with the fore/aft direction resulting in the left pontoon being miss aligned fore/aft with the right one. Joints 18 & 19 are the prime offenders
I have attach your model with the joints you specified located in the position you defined. I aligned all the joint to be as shown in the screen capture. I will caution you about opening my model in the same folder as your existing as this will duplicate your components. If you want to open it, upload it to a different folder.
I have no idea why, but when I went back to my file, I was able to adjust the position using the edit joint command. I had to determine the distance to move by trial and error. Thanks for your assistance. I'm still struggling with applying the joint command.
