Components versus Assemblies
kmilam
Message 1 of 9
kmilam
I'm coming from a SolidWorks environment.  Typically, I would create multibody parts in a part file, save out the individual bodies as linked part files and then reassembly in an Assembly file to add mates.  It was all so straight forward and enabled top - down design (albeit with a frustrating "reconstruciton" step at the assembly level.  Now, I'm trying to learn Fusion.
Can you please tell me the difference between a component (multibody with mates...or joints) and an assembly?
Thanks in advance.
Replies (8)
Message 2 of 9
jeff_strater
Fusion does not have a hard distinction between Parts and Assemblies.  Instead, there is a single concept:  Component.  A Component can be "part like" if it only contains bodies.  A Component can be "assembly like" if it only has child components.  Or, a Component can be kind of a hybrid if it contains both bodies and child components.
Components can be local (self-contained in one design) or external (more SWX-like, defined in a separate design).  Local or external components can be mixed and matched in the same top-level design.
If that doesn't answer your question completely, let me know.  This is a fairly broad topic.  There are lots of Youtube videos that I'm sure expand on this distinction.
Jeff Strater
Engineering Director
Message 3 of 9
jeff_strater
Message 4 of 9
kmilam
Thanks for reply.  So, what's the purpose of an assembly if the intermediate component does it all?  What is unique about the assembly?  Thanks
Message 5 of 9
jeff_strater
I'm not sure I understand the question.  If you can clarify the question a bit, that would be helpful.  There is no "assembly" in Fusion.  Thanks.
Jeff Strater
Message 6 of 9
etfrench
Perhaps Rule #1 would help.
ETFrench
Message 7 of 9
kmilam
Sorry, for the confusion, and thanks for your earlier reply.  I was using the term Assembly due to my background in Solidworks and Lar's use of the same term. https://www.youtube.com/watch?v=HBJMgkzkaas
So to draw a comparison to SolidWorks:  Solidworks has part files that can be combined with mates in an Assembly, and then that Assembly (and others part or assembly files) can be combined in a higher level Assembly file.
In Fusion360, I just need to swap the term Assembly for Component and Part for Body.  Is that about it?
Message 8 of 9
jeff_strater
@kmilam - close, but not quite.  Both Solidworks terms (Part and Assembly) map to Component in Fusion.  Body is the same concept (a self-contained group of geometry) in both products.  A Component can act as a Part or as an Assembly (or a sub-assembly), simply depending on what it contains, and how you use it in your design.
Here is an example of a component which is "part like":  it has a single body:
Next, I added a new Component to the design. (sub-assy 1).  It has two child components (SA part A, and SA part B).  That object is still a component, but because it has child components, you can think of it like a sub-assembly.  This hierarchy can continue as deeply as you want it to go
Does that help, or hurt?
Jeff Strater
Message 9 of 9
shahriarsifat1802164
Hi @kmilam ,
The good thing is you do not need to worry about lost the link of multiple components during assembly.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
