Component won't lay flat on plane
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
Ok I've been trying to figure this out for a couple hours now. I have two components that should be on the same plane but when I try to create another component that connects them it appears they are not in the same plane. I'm going to reference my file from here on out so this won't make sense unless you open the file.
Component "OUTSIDE ARM PLATE" and "INSIDE ARM PLATE" are copies of each other and when I copied one from the other I simply moved it in one direction roughly 1.5" (should still be in the same plane). When I'm trying to draw "HELP ME COMPONENT" to lay flat on top of the other two components one side will touch and the other side will be higher or lower than the other side. I've tried sketching directly on top of "OUTSIDE ARM PLATE" or "INSIDE ARM PLATE", I've tried creating a new plane directly on top of those components etc. I'm at a loss as to why the "HELP ME COMPONENT" won't lat flat across them. For reference, I'd like it to fit like the "ARM CAPS" component. Any help would be greatly appreciated!
Thank you
