Component Deleted When Selecting Sketch of Another Component
I have a sketch with 3 components in it. It's quit simple, built from the ground up with no externally referenced parts or whatnot.
Currently, if I double-click on Component 2's sketch, all of Component 3 is deleted.
I have attached a gif showing the behavior.
I tried exiting Fusion and restarting, to no avail. Thoughts on what to do?
jeff_strater
That component is not deleted.  When you edit the sketch, Fusion goes back in time to when that sketch was created - before "FuzeAndRetainer" was first created.  This is one of the basic principles of history-based (Parametric) design.  When you exit sketch mode, that component will come back.
Here is a screencast that illustrates the concept: (contains audio)
Here is a help article about parametric design:  About Parametric and Direct Modeling that might also help.
Jeff
Jeff Strater
Engineering Director
Thanks Jeff! I feel rather sheepish.
