Component assembly paths
paul.coleman
Observer Observer
paul.coleman
Observer
Observer
Does anybody have any experience or suggests suggestions of methods of working out if one component will fit through a series of openings / past obstacles?
For example, I am designing a coal stove with boiler. The body, being of welded steel construction, can't have any removable panels apart from the door. Inside the stove will be a set of components, including an irregularly shaped back-boiler. I want to work out if my design of boiler can be installed through the door?
This is a simple example to illustrate my point, and I have solved it simply by making the boiler narrower than the door. However, If I could have been sure it would fit, I could have had a boiler wider than the door, and installed it by twisting it through the door, much like getting a wide sofa through a narrow doorway.
How do the pros. solve problems like this? This must come up loads, especially in the automotive field!
wersy
That won't happen automatically.
I move the part bit by bit through the bottleneck and see if it gets stuck somewhere.
If you can't see exactly what's going on, you can use the Collision Control function.
