Complicated sketches debugging
walsashka
Message 1 of 8
walsashka
Hi, everyone!
I'm trying to make a sweep with a complicated long path (screenshot). But when I select "chain selection" I receive an error "The path is not smooth". And there is no way to see what the part of the chain is not smooth. The only way is to uncheck "chain selection" and turn on all the parts of the chain one by one.
Is it impossible to highlight the error part? And I'm talking not only about this type of errors, with all the warnings and errors are difficult to define the definite error place. I guess Fusion processing the data in the same way (one by one), so what the problem to show the part where Fusion is stopped on error?
Replies (7)
Message 2 of 8
davebYYPCU
Path Not Smooth - join between 2 lines is not coincident /Tangent, and is required.
Might help....
Message 3 of 8
laughingcreek
@walsashka wrote:
...Is it impossible to highlight the error part? And I'm talking not only about this type of errors, with all the warnings and errors are difficult to define the definite error place....
A weak point of fusion.  Would also love to see more work on these types of UI things.
Message 4 of 8
walsashka
Thank you, you're right about the solution. I know how to solve the issue, but you didn't understand the topic.
Message 5 of 8
TheCADWhisperer
@walsashka wrote:
Hi, everyone!
You should never ever have a sketch that looks like that.
And also an image of something similar that already exists in the real world.
Message 6 of 8
davebYYPCU
They have the Rail error highlight in Loft Tool, so not hard to port it over. (Big Red Blobs)
Message 7 of 8
walsashka
Thank you for trying to help me. But you should abstract of my example, I'm interested only in possibility of better debug system in Fusion.
Message 8 of 8
TheCADWhisperer
@walsashka
I read and understood your original post.
I have yet to see any CAD software achieve this goal.
The best, most efficient technique I have seen is diagnosis by experts with years of experience.
