Complex pattern on Fusion 360
Hi!
Is possible to make a compex 3d pattern, which follows the curvature of a rounded shape (as this grenade) in Fusion 360? Image below
TMC.Engineering
You sure can.
Steps are in the timeline in the picture.  Probably other ways to do it.
1. revoled barrel shape with horizontal notches.
2. create plane perpendicular to the barrel path
3. skecth notch on that plane
4. sweep (cut) verticle notch along path with chain off
5. circular patterc cut sweep feature
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Hi!!! Thanks for your reply! It will be awesome if you can put this as video. My english is not that good 😕
Thanks!
TMC.Engineering
Watch below. I use shortcuts so watch for those.  I want in and out of the revolve to add the horizontal grooves just to show you can.
Timm
Engineer, Maker
TMC.Engineering
don't for get to accept the solution if you like it 🙂
Timm
Engineer, Maker
Great TMC.Engineering
Thank you a lot!
