- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey there!
So I have this pot mesh (stl) that was then converted to BREP. My end goal is to create a 3d printable Pot mold, so I need to split this beast into two halves.
However, I am trying to avoid flashing lines, so I've created a rather complex selection lines which I then created a selection set. I have done this on both sides of the pot.
My question is, how I can split this pot using those lines. I've attached a screen shot of one of the selections. I tried doing a Surface extrude on the line, no dice.
In a previous model I was actually able to create a Loft (using lines that were twisted) and it magically worked, but that was modeled from scratch, not imported from an STL..
Any ideas welcome! Thanks!
-Marc
