Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to create a smooth soft transition (loft) between a 52 mm circle in bottom and a more complex shape at the top (marked light blue), 10 mm above. In the middle (5 mm up) there needs to be a completely flat circular surface 14 mm in diameter (marked darker blue). I have tried using 3 guide rails at the outer edges and a fourth guide rail tracing the needed outline shape from bottom, to flat surface and to top but it doesn't create a completely flat surface as seen in the pictures and there are strange curves all over making it not a very smooth transition. What to do?
Side view
Top view
NOT flat surface created
Very strange curvature
