complex assembly to house fixed size components. best parametric approach?
RishiWorks
Observer Observer
RishiWorks
Observer
Observer
Context:
Greetings, i am designing a case for an electrical device. There are fixed size sensor ports on the case and the internal PCB is standard dimensions. We are experimenting with various battery arrays and may need to scale down the overall size of the case to best suite users of the device.
Question:
Do you know of any best practices when modeling in fusion360 to best define, reference and link fixed constraints, that allow for ease of workflow / leniency enabling design variations?  Linked to context> Idea to  model all the fixed internals and sensors as components to then project / reference as much as possible.  It is a complex shape with compound curves etc. I have not had the best results in the past.
Cheers
Thanks for your consideration and any shared examples, workflow or tips.
Beyondforce
Hi @RishiWorks ,
Fusion has an amazing tool exactly for what you need and it's called "Derive".
https://www.youtube.com/watch?v=_tYCfuaagX4
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
RishiWorks
Observer
Observer
Thanks Ben.
Pretty cool feature. Ill look into the best way to maintain opening and fixture sizes, as i scale the overall casing size. It seems it may be through using a parameter file derived rather than deriving in the actual parts and trying to project and fix dimensions from them.
TrippyLighting
If the base design, the internals are of a fixed/static nature then I would not use derive but a linked component.
RishiWorks
Observer
Observer
Yes linking the components is certainly another option.  what makes sense to me most in my mind right now is to create a file and create prams for all the critical internal component geometries and use theses as sketch dimensions when sketching features. It would be nice to link the components and have them visually in the model, and link sketch dimensions to this ,but i dont find the project tool so easy to use for this, as i am unsure if the links are maintained going forward etc. For the sake of simplicity having a param file full of dimensions clearly labeled for each component will offer some fixed parameters.
