Complex Angle Faces: How to dimension in drawing?
tonySWCR2
Message 1 of 12
tonySWCR2
Hello All,
Attached is a simple sheet metal part that has non-perpendicular bends. This causes the face to be angled in all three main planes. In the example there are 2 holes on this face. How do I dimension them in a F360 drawing? I know how I would do it in other packages but Im lacking tools in F360. Can it be done?
Lets ignore that its sheet metal and you could flat pattern it, imagine its a solid part so making a flat component view isn't an option.
Cheers,
Tony
Replies (11)
Message 2 of 12
jhackney1972
It starts with a Named View in the model and then you create a modified Section View in the drawing.  I created a blog article and video on this process which you can view here.  I am sharing the drawing as a public link.  I have never done this before so I do not know how it will work.  You may have to use direct dimensioning instead of the dynamic dimensions for example I used the Diameter dimension command on the hole diameter instead of the dynamic dimension tool.  You will not get automated centerlines to work either, you could sketch they yourself.
Edit:   Look down further is forum question for a point that @laughingcreek made about how I went a little too far with my methods.  I got so involved thinking this was a great opportunity to show my method of Auxiliary Views I lost sight of the simple method of doing this.  Sorry, I hope you will take a look at my Blog article anyway.
John Hackney, Retired
Message 3 of 12
laughingcreek
@jhackney1972 -why the section view?  if you "look at" that face and name a view in the model, using that in the drawing produces a view that you can use center marks on, and avoids having to create a section view.
Message 4 of 12
jhackney1972
Good Point!  I got so wrapped up in the fact that this was an example of the method I used in my blog article on Auxiliary Views I guess I missed the obvious.  I can't see the forest for the trees!  I will edit my post, thanks.
Message 5 of 12
tonySWCR2
~deleted~
Message 6 of 12
tonySWCR2
I had kind of half muddled my way to the point of using section views as aux views but its so hard to get them to line up. Found a video you made on youtube which helped, using the green boxes and dragging across the dotted line to keep the view parallel. Where I was going wrong (by which I mean, where fusion fails me) was trying to use the smart dim tool, I just tried with the linear dimension tool and it works! Unfortunately, still no centre marks.
Cheers for you help.
Message 7 of 12
jhackney1972
As @laughingcreek pointed out, using a Named View takes care of everything, including the Center Marks.
Message 8 of 12
chrisplyler
Unless there is some reason that this isn't acceptable...I would just dimension them on the Flat Pattern view.
Message 9 of 12
tonySWCR2
So it does.
My real life problem has the face obscured by another feature in the component so I had to use your method, therefor loosing the CM's.
Message 10 of 12
tonySWCR2
@chrisplyler there is always one
"Lets ignore that its sheet metal and you could flat pattern it, imagine its a solid part so making a flat component view isn't an option. "
Message 11 of 12
laughingcreek
@tonySWCR2 wrote:
...My real life problem has the face obscured by another feature in the component so I had to use your method, therefor loosing the CM's.
if you start looking straight on b/c you used a named view, the cross-section is much easier to draw.  you can have your obscured view and also have your center marks-
Message 12 of 12
chrisplyler
Sometimes I am the one. It happens.
