Common Tolerance Zone between two surfaces
tjslo
tjslo
I've got a drawing where I want to specify a common tolerance zone between three surfaces.
The conventional way to do this is to use a multi-leader leader from a Feature Control Frame onto all of the surfaces and then annotate it with the 'CZ' markup, but this isn't available in Fusion360 yet. Does anyone have a neat workaround since the way that I'm doing it at the moment (individual frames on each surface) leads to a tolerance stack-up that could make stuff not fit properly.
The attached image shows what I've got and ultimately what I'd need. Is there a halfway house that anyone's using until the drawings team at Autodesk manage to ship  this feature?
ClintBrown3D
Hi @tjslo
We are going to be adding Multi-leader support to the drawings environment in a future release (see the roadmap).
Would using a leader work for you in the meantime? In the animation below, I add leaders to the FCF (suing the Note tool).
The drawback of this (for now), is that the leaders would need to be adjusted if the FCF moves.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
tjslo
Clunky, but it worked for now. Looking forward to the proper support that's mentioned on your roadmap!
cdun84
Observer
Observer
YEA ITS 2025 AND STILL NO MULTI LEADERS   . . . APPARENTLY ONLY 2 PEOPLE USE THEM THAT IS WILD
