Combining two separate drawings/parts into one part
flssfabrication
Message 1 of 8
flssfabrication
So, I'm new to Fusion. I now realize there is a way to do two separate components in the same sheet. I did not realize this so I drew two separate parts on two separate sheets. I figured out how to get them both on the same sheet but cannot figure out how to put the two parts together to make one part. I need the parts to be centered with each other and flush together. They are oriented correctly in terms of I need the boxed part on top of the two-sided part. I will attach my file and hope somebody can teach me. Thank you in advance.
Replies (7)
Message 2 of 8
jeff_strater
fortunately, you have made two components here.  That's good.  The way to relate two components is to use Joints.  In this case, we want a rigid joint between these components.  It was not clear what orientation you want relative to these two components, so I just made a basic one.  If you want a different orientation, a more complex Joint might be needed, or you may need to create explicit Joint Origins.
Jeff Strater
Engineering Director
Message 3 of 8
flssfabrication
Jeff, thank you for the help and the screencast. I need to explain my orientation a little better. I need the flat side with the slots of the taller piece to be on the flat side (the side opposite of the extruding flanges) of the shorter piece. When I attached my file, I tried my best to orient them how I needed them to be combined. Sorry for the lack of description, thats my fault. Can you help me combine these two in this way?
Message 4 of 8
flssfabrication
Here is my screencast of what I am attempting to do. The holes in both pieces should be centered, which will center the pieces together.
Message 5 of 8
flssfabrication
Screencast
Message 6 of 8
jeff_strater
sorry, screencast is still missing.  Even just a screenshot of the desired orientation (using Move Component) would be helpful.  I'll take another guess at what I think the result you are after.
Jeff Strater
Message 7 of 8
jeff_strater
Is this what you need?  In this example, I created a sketch in one component to use as a snap point for the Joint:
Jeff Strater
Message 8 of 8
flssfabrication
Jeff, that is exactly what I was looking for. I apologize for my troubles loading a screencast. I'm a rookie. I appreciate the help, it keeps rookies like me away from frustration and moving in the right direction! Thanks again.
