Combining to bodies makes mesh export fail
hoegge
hoegge
When I combine two bodies into one the exported mesh (using the make button to export to 3D print) has errors. The two separate fairly simple bodies export fine. See the screencast to show the problem.
If I export the meshes of the two bodies separately and combine them in Meshmixer the result is as expected - not wrong extra surfaces added.
Is this a bug or my mistake. You can see the original file here: http://a360.co/2ji6H2L
kr
Morten
PhilProcarioJr
@hoegge
The problem is the top face of the bottom part is concave but the bottom of the top part is flat so there is a gap which creates an infinitely thin connection.
I'll post a screencast when it uploads.
Phil Procario Jr.
Owner, Laser & CNC Creations
PhilProcarioJr
@hoegge
Phil Procario Jr.
hoegge
Hi
Yes - thanks! You're right - of course - it only touched the upper part with an infinitely small edge so bound to go wrong. Thanks a lot for your quick answer.
hoegge
Hi
And it is really great the ability to do these screencasts and share the 3D files. Autodesk has really made a cool solution with Fusion 360
kr
Morten
