Combining Multiple Separate STLs
So I have lightsaber hilt which im re-touching and changing around. Though, it's been divided into multiple small sectors. So, is there a way to open all the STLs in the same design page (Tab?) on fusion 360. Thanks in advance.
jhackney1972
No, I do not think this is possible.  You will have to open them one at a time, convert them from Mesh bodies to BRep bodies.  You can then take the individual solid bodies and combine them into one solid body.
John Hackney, Retired
laughingcreek
You can "insert" (from the insert menu, not "file-open") as many meshes as you would like into a single fusion model.
The next bit of advice you'll likely get though is that fusion ain't so good at doing things with .stl files.
can you post some pics.
