combining 2 components
brianne9SFZY
brianne9SFZY
I can open two separate files in Fusion 360 and they show on the tabs.
How do I get them to both be on the same  screen so that I can create a joint between them.
One is an internal gear and the second is a spur gear
Brian
jeff_strater
you need to create a 3rd design (think of it as an assembly).  Insert both into the assembly, and create your joints in that top-level design.
Jeff Strater
Engineering Director
brianne9SFZY
Thanks Jeff
By insert, do you mean Open?
g-andresen
1. create a new design and save it
2. insert your designs from datapanel
günther
brianne9SFZY
Thanks for the help.
Success. I now have both items in the same project.
My next thing is to test the gear fit.
I guess I will have to create a base for them to rotate on with pins.
See how we go.
Regards
Brian
