Combined joint help please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I'm relatively new to Fusion 360 and have found myself stuck on a certain type of combined joint. It's two opposing sliding joints that have arms and the arms are attached at their bases with a rotating joint. I'm trying to link them and just keep getting a warning error that it doesn't work when I create the lower rotating "revolute" joint.
I can't figure out the combination of joints or how to motion link them to get it to work. I was able to use the "enable all contact" without making the lower "revolute" joint, but it just worked for a couple of movements and then popped out the bottom joint. Even though I had it centered.
So I'm including a sample Fusion 360 (.f3d) file of the type of joints I'm trying to do. This isn't the design itself, but it's a good stand-in for what I'm trying to get done in my actual design. Below is a screen capture of the type of motion I'm talking about for further visual reference. The movement I want to achieve.
Thank you in advance for any help. I'm really stuck and this sucks lol.
