Combine is not working as needed
dennisbrandt
dennisbrandt
I have 2 bodies that I'm trying to combine. The first is a map of Florida. The second is a large U. I want the U to be 'over' the State such that the outline of the state that the U is over, goes away, i.e., the U shows as one 'body' and the State only shows where it is not covered by the U.
Sorry for the problem definition. I've attached my project.
KristianLaholm
If the attached image is correct.
Edit "Extrude13": Select the complete U-profile (3 profiles); Extent = All, (Cut thru "Florida")
g-andresen
this way ?
günther
billbedford
You missed a step. You need to make an extrude of the inner parts of the "U" as a cut in the map so that you remove the outline of the map that is inside the "U".
