- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi There,
This is an operation I have previously done a 100+ times in fusion and I am now having trouble with.
I will likely have to share my design with someone to investigate.
I exported and then imported a design to create a copy and then I have scaled it by 0.85 to give me a 15% reduction overall.
Then I am working through inserting new pins that have to be the right size, locating them into the pre exisiting holes, and using the combine / cut intending to open the hole size back up for the pin.
However, after the cut, it appears that the hole size has not changed, see second image, where it can be seen to be smaller, as in the original size after the 15% reduction.
As commented, I have used these combine / but operations so many times before without issue 😞
I am suspicous as if I try to just move the component, the move interactive axis are far away from the pin, back where it was originally imported. My suspicion is that although correctly rendered the code believes the pins body to be back where it was inserted!
I know it is not the component I have inserted that is the problem, its new as it is a shorter pin than before, as I have tried with the original "standard" pin that I have always used before.
It suffers the same problem. It does not get cut into the other body, and its move axis have not followed the component, when I used joint to get it into the correct position.
I have never seen this before and my workflow has not changed.
