Combine function not cutting when using a Mcmaster part
mstohner
mstohner
Community Visitor
Community Visitor
HI, im trying to model 1/4 npt threads in a part and when I insert a part from mcmaster and try and us the combine function to cut the threads so that i can 3d print the threads. I get a error every time that says make sure there is overlap. i used a joint to position the parts where I want to make the cut. I attached the file I am still learning any help would be greatly appreciated. Matt
TheCADWhisperer
@mstohner
jhackney1972
Your McMaster-Carr component was flawed.  I replaced it and all works fine.  Model attached.
If my Forum post solved your question, please select the "Accept Solution" icon. If you still have questions, please ask.
John Hackney, Retired
mstohner
Community Visitor
Community Visitor
Thank you for your help. I never thought to try a different component from mcmaster.
TheCADWhisperer
@mstohner
You could Unstitch and then Restitch the original geometry to repair the body.
