Combine cut a component from another complex component of components...
- Mute
- Permalink
- Report
So, I'm probably still low on my learning curve, but yet I was already happy where I got, but I'm stuck at this very step.
I have a spiral based design. Itself based on a spring of course. And now I have to cut "windows" on the walls. I tried pattern on path but that would rotate the cutting shapes so that they loose their "horizontality". Then I decided to do a pattern on circle, and I started to move up the remaining 15 windows (on 16) to get my first loop correclty. I then made these 16 components a 'floor' component which I copied two times for each of theù 3 "floors" in a final component.
With history tracking, I'm very happy that I can change the shape of the initial "window" shape and that it would reflect on all of them.
Bu I'm stuck with the cutting. I need the "green" to cut the "brown". And I cannot combine the "super component" with it. Is there a trick in the timeline that would repeat the component cut to the brown component everywhere?
Or another solution? I'm sure there is. But I wonder also wich is the best one ;-)?
Thanks!
File: f3z file
