Color Picker -Slider
admaiora
Mentor Mentor
admaiora
normally the slider in the control picker control the color luminance.
Minimum > Black
Maximum >White
In all other software in the market i have this correct  behavior:
In fusion we have as minimum > Black, correct,
but as maximum not white.
Is there any reason?
Thank you!
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
innovatenate
Autodesk Support
Autodesk Support
I note if you move the saturation to 0 it is easy to get a white color. This can serve as a good work-around solution for now. I'm not sure if this is as-designed behavior or not. I have logged report ID FUS-24808 to track the progress. I or another member of development will follow up to let you know the results.
Thank you for reporting this issue. If you have any questions, please let us know.
Nathan Chandler
Principal Specialist
admaiora
Thank you Nathan!
Admaiora
