coil that wraps around cone
dr.kaban
Message 1 of 8
dr.kaban
hi, I have a cone and I need a coil to wrap it around, but standard coil function does not seem to have an ability to make any coil shapes other than cylindrical. is there any way to get around this limitation? I have seen youtube video where a guy uses "helix generator" add in, but it does not work with current fusion version.
in the picture is not a cone but more complicated shape, still wrapped around with coil - made with the help of "helix generator" add in.
thank you.
Replies (7)
Message 2 of 8
jhackney1972
No need to use a Fusion 360 add-in, the application can do it already.  Here is model with one method shown.
John Hackney, Retired
Message 3 of 8
dr.kaban
thank your for your example - it helped to figure out how it works. never seen any tutorial about it 🙂
Message 4 of 8
jhackney1972
Attached is another method of creating the same design. This one takes a bit more planning to get the two features to line up correctly.
Message 5 of 8
TrippyLighting
No plugin needed:
Message 6 of 8
dr.kaban
thanks for sharing the model. however I cannot see the full history of creating that. first element i see is a coil. i don't get how do you set up different diameters at the bottom (8") and the top?
Message 7 of 8
JEFFSCYLLA
Community Visitor
Community Visitor
Thanks all, this examples is very instruktive
Message 8 of 8
asgregor78
Observer
Observer
Great video!!!! Exactly what I was looking for!!!
