Cleanup after Joining
FlyinBrian
Message 1 of 8
FlyinBrian
New F360 user here with a question regarding cleanup after joining--
I've noticed part of a joined body remaining inside another body after joining and would like to remove this. See attached pic of the rectangle where it enters the round tubing. The removal of the body protruding into the internal tubing is desired.
Any thoughts how to accomplish this?
Please forgive my ignorance as i'm very new, trying to learn F360 and the associated language. I'm also probably not describing my issue correctly here...
  • join
Replies (7)
Message 2 of 8
laughingcreek
"spit body" using the desired face as a tool?
p.s. usually a good idea to attach a model demonstrating the issue/question.  you get better answers that way.
Message 3 of 8
jhackney1972
I created a sample model and a Screencast to illustrate a few scenarios of what you may have.  As @laughingcreek has already done, please attach your model and you will be sure to get a correct answer.   If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
Message 4 of 8
FlyinBrian
Appreciate the response. Hopefully have the model attached here now. If viewing inside the tube, the body that was joined can be seen protruding into the inside of the tube. Attempts to select and delete, result in error messages..... i'm looking to learn how to clean this up?
Message 5 of 8
wmhazzard
Control select the inside faces and hit delete.
Message 6 of 8
FlyinBrian
Thank you guys! When previously trying to delete I was selecting only 1 face at a time and couldn't figure out what was happening. Once I selected 'z' plane face and an 'x' or 'y' plane face together, it worked great! The section analysis tool really helped with this.
Message 7 of 8
laughingcreek
The ability to delete faces and have the model "heal" itself is a direct modeling ability that made it's way into fusions parametric side.  It's a fantastic tool for dealing with modeling issues that might be difficult to do other wise.
but
it's not very robust.  modeling changes can easily cause a different number of faces to appear (more or fewer), causing the delete features to fail.  That's fine if they were used to fix a small number of problem spots, a pita if you are in a habit of using them throughout a larger project.  It's a good idea to seek out a process that is less likely to fail due to parameter changes.  Attached is an example, I'm sure there are many more. (also doesn't require hunting around for all the faces inside a pipe)-
Message 8 of 8
laughingcreek
just to drive home that point, here's a quick screen cast of changing the thickness and diameter of the pipe using the model @wmhazzard posted vs the one I posted.
