Circular pattern seemingly cutting at random
TheAHan
Message 1 of 14
TheAHan
The screencast below shows my issue. I create a pattern using faces that I want to cut, and then not all of the generated faces are cut. Can anybody see anything I'm doing wrong?
Replies (13)
Message 2 of 14
robduarte
I don't see anything that you're doing wrong. I'm just curious - have you tried patterning it as a feature?
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Message 3 of 14
TheAHan
It won't allow me to select the faces under the "feature" pattern type selection in the circular pattern tool. Is there another way to select those faces as a "feature"?
Message 4 of 14
Beyondforce
Hi @TheAHan,
Please attach the file, so we can test it.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 5 of 14
robduarte
You have to select features from the timeline. IE: if that cutout was created with an extrude, you could pattern the extrude feature.
Rob Duarte
Twitter | YouTube
Message 6 of 14
TheAHan
@robduarte Thank you very much! Using feature as the pattern type did indeed work as intended, however I still have no idea why faces doesn't work as it gives the correct prediction...
@Beyondforce Would you like the whole assembly or just the affected body, and what file format would you like?
Message 7 of 14
Beyondforce
Export the whole assembly as *.f3d file and I'll take it from there.
Ben Korez
| YouTube
Message 8 of 14
TheAHan
@Beyondforce Thank you, attached
Message 9 of 14
Beyondforce
Here you go. I hope this will help you understand the difference between a Face and a Feature (face) and when to choose one or the other:
Cheers / Ben.
Ben Korez
| YouTube
Message 10 of 14
TheAHan
@Beyondforce That was quite helpful, thank you very much.
Message 11 of 14
robduarte
Yes, this is what I suggested early on. Honestly, though, I don't think it addresses the original poster's problem. Yes, patterning a feature is the best choice in this case. But as you proved in your video there is no reason why patterning a face shouldn't work as well. In addition, the behavior when he tried patterning it as a face -- not an error but a strange pattern that is missing random instances -- seems more like a bug to me than a user/workflow problem. There is no documentation that I know of that suggests that faces created as a result of a feature must be patterned as a feature. (And if that were true then it shouldn't be possible to attempt it.)
Rob Duarte
Twitter | YouTube
Message 12 of 14
TheAHan
@robduarte I feel you are absolutely correct; I accepted the answer @Beyondforce gave because it offered a better understanding of how fusion works and when to use these different tools. On the other hand, the pattern tool does seem like it should work either way so to be intuitive to any thought process (One of the things I love about Fusion). It even gives the correct prediction before the random cut!
Message 13 of 14
robduarte
No problem - I'm not competing for the Solution credit 🙂 .. just trying to determine whether you should submit this as a bug!
Rob Duarte
Twitter | YouTube
Message 14 of 14
TheAHan
I just did haha. Thank you for your help!
