Circular pattern multiple features?
patrik-web
Message 1 of 9
patrik-web
It seems that when using the circular pattern (and I assume the rectangular, too), if you are patterning faces or bodies you can select multiple ones but when I attempt to pattern features it's only possible to select a single feature. Is that known/intentional?
Replies (8)
Message 2 of 9
randyT9V9C
Try selecting the Features from your timeline at the bottom.
Message 3 of 9
patrik-web
That's what I tried, but it doesn't work. See attached screencast.
However, I just made a new design with a a couple features to test this, and then it works. There must be something special about the features I'm trying to select...
Message 4 of 9
jeff_strater
When you edit the Pattern, try holding down CTRL (Cmd on Mac).  In general, you need to hold down this modifier to add to selection sets when editing a feature.
Jeff
Jeff Strater
Engineering Director
Message 5 of 9
patrik-web
Doh! I didn't realize that applied also to selecting things in the timeline.
Message 6 of 9
r.moss
I'm seeing something very like the above problem.  I have a threaded hole in a boss.  When I try to make a circular pattern of 4 threaded holes, none of them are visible.  Even the original hole disappears.
Edit Feature shows the hole and its thread properly selected in the timeline.  I've done this lots of times and it has worked in the past, but now it seems to be broken.
The screencast is here (I cannot embed the screencast - just get a message about invalid html.  This has been a forum problem for as long as I can remember).
Message 7 of 9
r.moss
Ah, the "embed" html from my screencasts just points to the parent page.  try this:
https://knowledge.autodesk.com/community/screencast/a730424f-0515-4397-9314-97e3e94e8357
Message 8 of 9
laughingcreek
the patterned extrude files in the threads. you only need to do the extrude once, and only pattern the threads (and set pattern to optimized)
Message 9 of 9
r.moss
Thank you.  I hadn't appreciated the subtleties of Optimised, Identical and Adjust.  Maybe it would be better if "Optimised" were the default, if that's the one that works (not sure why Adjust shouldn't....?).
I wonder if I ought to go back through my models changing Adjust to Optimised in all the patterns!
