Circular pattern bug when patterning partial depth threads.
pmesten18
pmesten18
I am having an issue with the partial depth thread function. the holes seem to pattern fine when being modeled threads with full depth, but then when using a partial depth, things fall apart, either they don't pattern, or the threads cut into the body in seemingly random locations.
p.s. is there a better place to write up and report bugs than the forums? I'd like to help point them out whenever I find them if it helps make fusion a better product!
Thanks.
laughingcreek
can yo post what's not working for you.  when I edit the threads you have patterned to make them partial threads it seems to work fine.
pmesten18
You can see in the image i attached in the original post that there are threads cut into the end face of the part. those threads should be modeled in the 3 holes on the hexagonal faces.
If i change that hole to be non-modeled threads, the threads pattern fine.
When the threads are modeled they do not show up in the right holes, and are off in seemingly random space.
laughingcreek
seems to work when "compute option" is set to "optimized"
