Circular joint
Circular joint
BIMDraughting
Message 1 of 8
Circular joint
BIMDraughting
Hi
I am a new to Fusion and trying it out I am from AutoCAD and Inventor,,,, how do I do this joint in Fusion.
a pipe into a cut out in shell trying to model a manhole on a tank.
the joint always goes 90deg how do I rotate it?
Replies (7)
Message 2 of 8
Warmingup1953
Do you mean Joint (as in fusion 360 Joint) or do you want to model 2 bodies?Autodesk_Fusion_360__Education_License_.jpg
Message 3 of 8
BIMDraughting
trying to model this,
Message 4 of 8
BIMDraughting
is it nor possible to rotate, driving me mad why cant I constrain to a plan or centreline/axis
Message 5 of 8
TheCADWhisperer
@BIMDraughting
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
I would model in Fusion 360 the same way that it is modeled in AutoCAD or Inventor. (Geometry is geometry.)
Message 6 of 8
BIMDraughting
Hope this works first time exporting
Message 7 of 8
BIMDraughting
I redid the part and made a rigid group now it is in place
Message 8 of 8
davebYYPCU
Rigid Joint the centre points of the 2 sketches.
Set the offset distance in the dialogue box.
Might help...
