Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Circular cut pattern leaves slivers of body
4 REPLIES 4
ptr727
380 Views, 4 Replies
I am making a simple spacer, when I rotate the cut the result leaves slivers of body behind.
Other than making the cut drawing much larger than needed, is there a way to fix it such that the cut works?
4 REPLIES 4
TheCADWhisperer
in reply to: ptr727
@ptr727
Your sketch isn't fully defined.
See Attached.
Blue lines and white dots (and brown construction lines) should keep you awake at night.
Tip: When geometry doesn't show as fully defined - click and drag and observe.
ptr727
in reply to: TheCADWhisperer
Thx, I see that now when zooming in.
That's interesting, the circle and rectangle were drawn centerpoint and coincident on one edge, and then the other dimensions set to equal.
If I do make it coincident I get an over-constrained error, I'll redraw and use constrained instead of equal dimensions.
TheCADWhisperer
in reply to: ptr727
@ptr727
You could have created the slots with a single line and Thin Feature Extrude rather than using a Rectangle.
g-andresen
in reply to: ptr727
Simply create a tangential relationship between one (short) side of the center rectangle and the arc.
Günther
