circle becomes unconstrained when trimming
When I trim part of a center diameter circle line turns blue indicating that the line is unconstrained. Is this normal or am I using wrong procedure?
Beyondforce
Hi @Anonymous,
You forgot to trim a line. As you can see in the picture, the white dot is belong to the line that you need to trim.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
TrippyLighting
The question I have is why would you need to trim at all ?
While the sketch might look a little convoluted, often trimming and the necessary cleanup and re-contraint work that go along with it are not necessary at all.
You can select and extrude/revolve many regions at the same time and if they are adjacent they will all be joined into one body.
Thanks for the reply Ben,
That didn't seem to help.
It looks like I was being too fussy.  See TrippyLighting's reply
Ray
Thanks for the reply.  I'm fairly new at this and I have watched a lot of Lars Christensen YouTube videos.  In one of them he spends a lot of time talking about the importance of having fully constrained sketches.You mention that if the adjoining elements are constrained it's not necessary to constrain every element of a sketch.  Are there any other conditions where I don't have to bother with constraints?
