Changing view on 2d drawing
Is there any way to change the view that you see in the viewport on a 2d drawing.  The view options seem pretty limited and I only seem to be able to select from a drop down to view the front of the unit from NE / NW / SE / SW - none of these view allow me to see the back of my model (in isometric).  Also is there any way to change the view from isometric to perspective without rendering and adding an image.  In future I'd really like to be able to click into the viewport box and adjust the view (in iso or perspective) to what I want to look at.  See this video link that shows me adjusting some views in the software I currently use.  Im able to change / customise views in the 2d drawing and can work in perspective and in colour with textures visible (no rendering required).   The absence of 2d design features like this (and the other wish list items raised in this Idea Station post) are what's holding me back from adopting F360 as my main software.
For now I'd really like to know how to get a 3d view of the back of my model on a 2d drawing?
Any help or advice much appreciated....
@Anonymous
What you can do with the current version of Fusion 360 (still a bit limited)
1) in Model-workspace, orbit to desired view direction
2) save this as a named window
3) refer to this named view when creating a drawing view - if you want a shaded version -> select "shaded"
Example
@Anonymous, thanks.  That's good for now - thank you for the clear explanation, much appreciated.  Hopefully in the future it will be possible to show perspective views and to adjust within the drawing space.
All the best
Sam
